The other day I looked at the undercarriage of the car. It looked like a lot of dirt from the road got stuck to the bottom of the engine.
I showed it to a mechanic. he said it is just undercoating.
I have seen a detailed undercarriage of a 996. It is so clean you can eat on it. It doesn't have that "undercoating" on it. Maybe when the car was detailed the undercoating was removed? I don't know.
I wonder if the 996 comes with one of those textured undercoating?
Just curious. :renntech:
Porsche uses a product called cosmoline-it's a type of undercoating and looks very dirty/brown.
Yup, it looks like that. Is our engine made of aluminum? I wonder why Porsche feels the need to spray that kind of undercoating on the bottom of the oil pan.
Edited by The Hoth
Correct, the engine is made of light alloy. The product prevents corrosion for some time.
Well, I guess all I have to do is to hose down the carriage once in a while and forget about to scrub it clean, cus it will remove the protective coating. :D
