the stock bulb shows 55w i only saw 100w at the store, i know it will work but will it burn up the fixture? i know they only turn on when you turn so they arnt on all the time so they have a chance to cool off.
Anyone done this before and or had issues with this wattage?
thank you
vincent
Only H3 55W bulb is recommended, 100W is too hot for the unit ( melting ) and the control box will give you fault codes on the display as well.
