Could anyone help me to remove the instrument cluster cover so that I can install the microphone for the hands free kit. I have read the TSb on installing the hands free kit but it doesn't help too much.
Any help much appreciated.
Its easy to do but the micrphone slot in the console pod is not a good place for the microphone despite there being a home for it there.
Best place is by the visor or by the reversing mirror. I have mine up the windscreen post next to my visor. It's held there using velcro and works great. (see pics below)
Getting the console pod off:
Adjust the steering wheel so that it is fully extended.
Place a towel over the steering column (stop scratches)
Use a butter knife: prize off hazard warning bezel and the switch cover.
Prize off the microphone slot cover.
You will see a torque screw in each side where you prized the bits out.
Undo these and lift the console pod up. Rest it on the towel.
May need to heave-ho on lifting the pod up.
On the back there are 3 connectors (blue, black, white)
There are flip-over holders over the connectors. Lift them and the
connectors will come out.
Under the pod, use a "plastic" screw driver and prize the hazard switch
off its connector. The connector will then pull out and the console pod
can be lifted out the car. Viola!
I can do this in about 5 minutes max.
Microphone on my drivers side upper windscreen post.
(excuse the messy garage)
Inside of my car:
Edited by Scouser
Scouser, just to let you know your instructions were spot on. I removed the cluster and fitted the microphone - remembered to use the blu-tac on the end of the screwdriver trick to get the screw back in behind the microphone.
Hi Matt,
I go down to Watford once a month. We must meet for a beer.
Besides I want to see that Kenwood satnav system you installed.
I'll be in touch.
Cheers,
Berny
  • 3 years later...
I have tried my best to remove the hazard warning bezel but it just won't budge.
What is holding it in there? Anybody have a picture of it?
Inside of my car:
Inside of my car:
I also tried prying my hazard button out yesterday and it wouldn't pop off. I didn't want to break anything so I just left it alone. If any one has pictures that would be great. I need to take my cluster off because I want to get my gauges done in silver.
Just keeping pulling - it is stiff but will eventually come off. The lugs are quite sturdy so i'd be very surpised if you managed to break them.
I discovered this very recently as I really struggled to remove the bezel, but it did eventually come off.
Neil.
Edited by NT_996
