I need to remove my rear door panel (interior) in order to check my lock. Before I ruin things I thould it is best to ask the people that know how to remove the panel?
Pics would be great.
thanks, frank
thanks Loren, you helped me out once again.
Regarding the aluminium trim: is it just a matter of pulling it off or do I need to move it sideways before pulling?
Thanks, frank
Thanks, frank
You dont need to remove the aluminum trim. Remove piece number 8 in the diagram and remove the two t30s, then piece 6 and remove some more t30s. Then there are two t-20s on the lower carpeted portion of the door panel. Then pull it off. The clips are a bit tricky but they run along the outer edge. Theres probably seven or eight all told.
