My 2003 TT does not make any noice when I use the turn signal. Could anybody tell me where the sound thing is located and whether it is easy to replace?
Thanks, frank
Thanks, frank
I have exactly the same problem. Dealer told me to replace the entire instrument cluster. Did you learn anything different? I don't see that anyone responded to you.
Thanks.
Brad
As far as I know the speaker for the turn signals is inside the instrument cluster. Does it make the ding noise if you drive without your seatbelt on? I know for a fact the ding for the seatbelt warning in inside the cluster and I would guess the speaker for the turn signals is as well. The cluster is not serviceable.
Edited by PTEC
Thanks. I will check it out.
