All of a sudden my window switches stopped working, 2001 996 cabrio. No water anywhere, 30 amp fuse for windows is good. When I put the top down the windows open and shut when closing the top. When I pull the door handle the windows go down 1/2 inch for clearance and back up once closed.. Is there a relay hidden somewhere or another fuse that controls the window switches only, seems like a relay ..I read there is a control box under the seat with a fuse but before I pull the seat.. (the power seat works by the way) I though the brain-trust on this site might be able to help. also the boot or trunk opens and everything else works fine.. Thanks
Wayne
When U undo the roof latch, does it lower your windows?
Wayne
