when i lock the car with the alarm key, it locks, but then unlocks and horn goes off twice. what could it be?
I had the same problem some time ago and it turned out to be a door lock microswitch. The locking mechanism operated, but the switch wouldn't tell the alarm system it was locked. As Loren says, you need a diagnostic check, which should reveal what is causing the problem. Meantime you can lock the car with the key using the emergency locking routine - turn the key to the lock position and back three times in quick succession.
