How many of you press the PSM button as soon as you start up your trucks? I've only had my Turbo for about 3 weeks and over the past few days I pretty much immediately turn off the PSM. I just love the increased throttle response and the tendency to hold gears longer. The regular program feels way too lazy and always upshifts when I'm about to merge. I know a couple taps of the tiptronic buttons gets me in a lower gear but the PSM-off program seems way more in line with how I drive. If only it had a manual trans....(sigh)
BTW, for those of you with chipped Turbos, does the new programming mimick the better throttle response of the PSM-off?
Edited by SeattleBum
I turn my PSM to "off" every now and then, but not always. It isn't really practical for driving slowly around town... always holding 3rd gear, etc. Sometimes I upshift with the tiptronic controls on the wheel in combination with PSM off.
It is certainly the way to go for spirited driving.
I guess I'm just having a hard time letting go of my CTSV's manual transmission. (sigh)
  • 4 weeks later...
Same here...turn it off now & then but generally drive with it on...the standard program has been optimized for fuel economy and thus emissions/CO2...great for commuting..
Chipping will yield more engine torque, thus indirectly affecting gearbox behavior
I rather put the tiptronic in manual mode, making a downshift with the stick rather then to use the selectors on the wheel because they will hold a lower gear only temporary (forces it to manual for about 5 seconds, then goes to D again and upshifts)
Lock the shifter in manual possition, you can use the steering wheel buttons than without automatic up shifting after 8 seconds.
Hi Guys,
I have a CS 04 and when i switch the PSM off via the button, it doesnt make a difference to performance or gear change...
any ideas?
Yes, your version of DME is wrong. It could be that the DME unit itself needs to be replaced also. All of this should have been done under warranty (mine was)
I had the same problem you describe for the first year until they got there act together.
Hi Guys,
any ideas?
Hi Guys,
any ideas?
Is there a TBS or the like for this?
I do not recall a specific one but there were quite a few, as soon as they hook up PIWIS they should see the version problem. It may require the replacement of the unit not just a reflash so if your out of warranty you might want to consider that it could cost a lot.
Hi Guys,
any ideas?
Hi Guys,
any ideas?
Mudman,
Can you tell me what version I should have....so i can give them a pointer, my model is a CS 2003 build? The dealer reckons that the PSM just turns the stablity control off and doesnt do anything else....any help is good.
Are you talking to a Porsche dealer ? if so I would be worried.
I don't know the version sorry, without hooking up the tester you cannot tell any other way.
Hi Guys,
any ideas?
Mudman,
Hi Guys,
any ideas?
Mudman,
Yeah...its a porsche dealer....hmm...i'm going to get them to look at it again, my starter motor is playing up....lucky its still has extended warranty.
OK, if your on a PCA warranty you will need to push harder. If you jump over to rennlist and search for DME, look for 04/05/06 entries, print some out and take with.
Hi Guys,
any ideas?
Mudman,
