Many moons ago I found a tip on how to enable the RDS function via the service menu. I thought it was neat, but now it's a lightly used gimmic in my area. I should have documented it, but now I simply forgot how to disable it.
The forum search didn't produce any results.
Can anyone help?
I was not aware you could turn RBDS on or off - I thought it was always on and stations that did not use it just show normal station info.
I had found this feature back in 01/02, but I didn't bother to write it down. If anyone knows how to access the service menu, the function to disable/enable this feature is there.
