hello there,am looking for some advice. boxster s my2004 and psm and abs light is on. turn off and restart and light off for few minutes. when checking with pst2 i get the code 4460 pressure sensor. anyone any ideas of testing this?
Fault code 4460 Pressure sensor
Pressure sensor actual value is evaluated and displays an implausible value.
Possible cause of fault
- Short circuit to ground/8+ or open circuit
- Plug connection on stop light switch faulty
- Incorrect adjustment of the stop light switch
- Wiring/plug connection between pressure sensor and control module faulty
- Pressure sensor faulty
NOTE: A malfunction of the stop light switch can cause this fault. The stop light switch must have switched before a brake pressure is recognized. When the brake pedal is actuated, the stop light switch and the brake lights are triggered. The brake pressure on the pressure sensor is 0 bar.
So, check your brake lights first.
thanks loren will check that tomorrow.
  • 2 years later...
I´ve the same problem with the 996 TT mod 04. Checked already all Possible causes of fault: 4460 ..........
Renwed the ABS modul and programmed with PIWIS . Still have the same problem. Any tipp for this fault code ?
Thanks in advance
911rs
