I had a problem with my car it is a 01 us 996 convertible and some how during storm I got flooded.
. It affected the car it was running like in 4 cylinders and the engine light was flashing. I took a sponge and after a wile I remove most of the water didn't wanted to start but after a wile it did. but my windows central locking and trunk release is not working. I check the 3c fuse and it is OK
I suspect that ifs related to a car computer but I hope not since they are very expensive.
Any suggestions I can not reseat the battery since I can't open the hood.
Remove the drivers seat and there is a control unit under it. Remove the control unit, open it up, and dry it out. Also check the fuse on the control unit. Check in the Boxster section as this has been covered several times. Unfortunately the control unit may have been exposed to water and electricity too long and may be fried.
Also, after you resolve the problem, be very sure to clean out your drains so as to avoid a costly re-occurrence.
Loren has posted a diagram of the drains on another thread. You can also look for a post by "Kim", where he did an excellent write-up on how to access, clear and empty the rear drain trays on a 996.
Regards, Maurice.
Sorry to hear this...
this is going to be very frustrating & expensive.
1 986 owner spent $2100 when his module was flooded.
Try not to unplug the seat wiring hardness
986 being a roadster, this is a well known issue for us.
When the seat wiring hradness is unplugged , it usually triggers the air bag light.
I haven't seen anyone can repair the alarm module yet, if there is I would really like to know & used one is really rare to come by.
ordering a new alarm module + new key to get programmed(unless u got a code for your old key,highly doubt it) is needed I believe.
Should we consider this fried? Attached pic Why not to remove the sea harness.
Could install a used one, could this be repaired?
Edited by juniinc
