I recently had the rear fog light go out and since replaced it with a new bulb (with a Sylvania bulb, not an Osram) the bulb seems to be working fine, but I am still getting a warning that the bulb is out. I replaced the Osram with a Sylvania of the same type. Any insight would be appreciated.
Have the new bulb the same VOLT and WATT ? ( 12V - 21W ) It is uncommon that rear fog lamp bulbs go's out in this short period of time, check the connector and the wiring as well.
It's the correct voltage and I'm pretty sure it's the correct wattage. The bulb was definitely not working and when I replaced it, it was working again, but I still get the warning to check the rear fog light.
