my car is 2001 c4 manual .
i want to change Gear oil and manual transmission fluid ( some like gearbox oil ???)
this two can buy from porsche ?
how many i need put in the car - Gear and Manual transmission fluid ???
You transaxle calls for a little bit over 3 qts. You need 90 GL5 gear oil. If you do not have a limited slip transaxle you may want to opt for a gear oil that does not have friction modifier in it. Redline makes a 90 NS GL5 with no friction modifier. Mobil 1 works well but has a fricition modifier. LS tranaxles need fricition modifier for their clutch packs to work without grabbing. When used in a transmission, it could give a notchy feeling since the synchros are not bringing the gear up to speed fast enough.
