By the time it's revved to 3k it's gone.
Just one tappet, I think.
Oil pressure seems good (5 bar at 3k)
More than 1 bar at tickover.
Don't know what oil (only just got the car) but I'd guess at Mobil 1
A higher viscosity oil like 15w-50 will give you a short hydraulic valve lash noise on statup. It seems that using the Porsche recommended oils 5w-40 seems to fix this.
I'm now told (by my local 'indie') that it's probably a failing piston and it may well need a new engine.
Cam covers and cams off with boroscope down the plug hole to find out ;-(
