I think I,m going to have to change a window regulator shortly - window squeaking loudly.I,ve found the instructions on removing the door panel but cant find the info on changing the regulator.Can you direct me to the relevent topic please.Also what parts do i need to buy?
i used this procedure. it's for a boxster but 996 is the same.
http://www.bombaydigital.com/boxster/projects/window/
