I bought a new hood crest logo. I got the logo, but I don't know how to get the old one out. I see two holes with limited acces to the backside of the crest pins, but I don't really know how to get to them.
KL
Edited by kristian
The are two small (cheap) self-tapping nuts on the back side.
The nuts need a small metric socket ( don't recall the size), and unscrew. access through the two small holes you referred to. The nuts on the current crest cannot be reused, you need to get two new ones. The hardest part is getting the gasket around the new crest before tightening down the nuts. Do not over tighten they will strip.
