Hi Guys,
Just had problems with the drivers side window. Took it in under
warrenty and they reparied it. They installed a new latch. After all
the reading I did on the 996 site, I was sure that the window regulator needed to
be replaced. They told me that the microswitches were worn out. If you
are a DIY er I sugest the latch first and the window regulator next.
The crazy thing about this is it happened 50 miles before my warrenty ended.
I just sneaked under warrenty with this. By tomorrow, my car will be
over 50,000 miles.
I love this car!!!
Paul
  • 4 weeks later...
There are multiple causes for the window not dropping. The window regulator is by far the most common cause for this. The problem is very easily diagnosed with a PIWIS tester as you can watch the microswitches inside the door latch and the two on the inner/outer door handles to see if they genuinely are a problem, which they rarely are. The 997 uses a different system than the 996 control the window drop but I still, as a DIY, I would not recommend replacing the door latch before the window regulator.
Edited by PTEC
