Hi Loren
I recently purchased a 99 996 C2 coupe, arctic silver/black. Love the car.
Reading this forum and other sources I get a lot of confusing answers so I thought I would ask you:
What do you use for motor oil?
What tire pressure do you use?
I have Michelins w/18" wheels. The car has 72k miles and is used mostly for city and freeway driving.
Thank you for your insight and taking time to respond.
Most of this has been covered elsewhere and there are plenty of other folks that can answer this and give you their opinions.
For my car I use:
I use Mobil 1 0W-40 (although I used 15W-40 when I spend a lot of time at the track)
I run 32 front and 36 rear (cold) - but for most folks you likely want to stick with the factory specs of 36 front and 44 rear.
I believe that tire pressures need to be dependent on your driving style. So, there is not a tire pressure that works for everyone. But somewhere between those ranges should be good for most folks.
