could anyone tell me what might be wrong with my car, i took my car to the dealer three times and still i get the check engine light.
they have changed the mass air flow three times now!
i checked for the error code and this is what i get:-
P0446
Porsche fault code 95 - Shutoff valve activated
charcoal filter (function)
P1128
Porsche fault code 360 - Oxygen sensing adaptation
idle range bank 1
P1130
Porsche fault code 361 - Oxygen sensing adaptation
idle range bank 2
PS my car was with the dealer for more than a month and still they couldnt fix it.
Edited by donjuan143
P0446 EVAP Canister Shutoff Valve (Function) – Below Limit
– Purge air line blocked
– Flow resistance of EVAP canister too high
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit/Below Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit/Below Limit
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
– Exhaust system leaking
My bet on P1128 and P1130 is an air leak. Oil filler hose, AOS, or other manifold leak.
i hope to god you are not paying them for parts or labor for them to read codes and swap the MAF 3 times. and you were without your car for a MONTH?! was the car running poorly or did you just take it in because of the Check Engine Light? i'm sorry, but you are obviously dealing with incompetents. take the car somewhere else. i don't know why they would try something three times and expect different results.
as Loren suggested, you probably have a vacuum leak (a hole in a tube) somewhere. the Air-Oil Separator (AOS) is always suspect. they just can't seem to get this part right. depending on your model year, the oil filler tube may be prone to cracks which would introduce a vacuum leak. have your gas cap tested to make sure it is functioning properly. make sure other caps (oil, coolant, etc.) are tight.
it would help to have all the details like model year, mileage, any work done recently, etc.
also, just because your car has a Check Engine Light doesn't mean you need to run to the dealer. most of the time, the CEL lights up (solid) for minor reasons and you can take the car to an AutoZone/PepBoys and have them read your codes for free - and then post them here. however, if your CEL is flashing, that means there is a potentially serious problem and you want to pull over and shut down the car as soon as possible and have it flatbedded.
so, if your CEL isn't flashing and your car is running normally, it's perfectly fine to drive. CELs clear themselves all the time. ;)
