I'm planning to replace oil, air and fuel filters this weekend (along with oil change). I haven't done the fuel filter before. Any issues or tricks to be aware of?
Also - what is the correct torque for the oil filter housing and the oil drain plug?
David
:renntech:
Tighten the filter housing to 25 Nm (18 Ft/Lbs).
Replace the crush washer on the drain plug. Reinstall the drain plug and tighten it to 48 Nm (35 Ft/Lbs).
For your fuel filter - remove the protective panel, remove the brackets for the pipes,,
Edited by juniinc
David
:renntech:
You can also follow the 996 instructions in the 996 DIY section. They will be very close to identical.
