Sorry, my bad - I grabbed the wrong image the first time.
It has now been corrected.
Thanks Loren. I am assuming the plug is #14 right?
Yes, and the sealing ring is 15.
Do you need the part numbers?
Thanks Loren! Part numbers would be great! Best site for Porsche DIY'ers!
For Cayenne (Gen2) V8 engines
Oil Filter 948.107.222.00
O-ring (if it does not come with the filter) 948.107.322.00
Sealing ring for drain plug 900.123.106.30
Loren,
For 04 Cayenne S, are the drain plug location, oil filter, and O-ring the same as MY 08.
Loren,
Yes, Cayenne (Gen2) V8 is MY08 through MY09.
Edited by Loren
Corrected model years
Look out Loren, Cayenne V8 > 06 ( 07 doesnt exist ) Cayenne V8 < 08 DFI use different oil filters, O ring is not including with 08. The location is approx. the same.
