99 Boxster, 5 spd
I did a search and found a lot of good info but not one post of a gasoline smell at low speeds just after shifting. The local autozone pulled the codes and came back with TPS Sensor, changed it, I cleared the code with the reader, and one day later it is back.
I plan to clean the MAF. Check for vacuum leaks with starting fluid.
Any other idea's? Where is the Air/Oil seperator located?
Thx
99 Boxster, 5 spd
Thx
Please do a search here - those codes have been covered many many times.
99 Boxster, 5 spd
Thx
I thought I covered that when I stated " I did a search and found a lot of good info but not one post of a gasoline smell at low speeds just after shifting".
I would appreciate your input instead of covering what has already been stated.
The gas cap is fine, I checked that one, great idea though.
Edited by Cruzin
