reset per the manual BUT after opening either window it will come right back up rather than staying down untill door shut. 03-carrera coupe.
Any suggestions?
Any suggestions?
there was some good info on this at 6speed. basically, with key on, lower window, hold button for 3 secs, then raise and hold for 3 secs. I had to do this several times before the re-programming took hold. and, just flic the switch for a nanosecond, any longer and the auto feature is disabled. hope this helps.....
