P0304 Cylinder 4 misfire
ok I have a bad consistent misfire and have a p code p0304.
Now I've pulled the coil pack and checked the connection and the sparkplug and all looked fine. I put it all together and forgot to plug the wire back onto the coil pack and noticed the misfire hadn't gotten any worse or better so I think my coil pack is bad. Anyone have any input on my diagnosis?
Anyone know the readings I should get from the coil pack if I hook it to a Ohm meter?
Need this info asap cause in here at the shop and want to get this show on the road, thanks in advanced
Im not sure thats right... I pulled the connection from the 2nd cylinder on the drivers side and got a misfire cylinder #5... and the head on the passenger side looks alot further forward than the Head on the Drivers side of the engine.
So i assume its:
FRONT
4-6 | |1-3
REAR
TRANSMISSION
Reverse this as it is for a Carrera.
You don't need to reverse it, the cylinder numbering is the same between the Boxster and 911, just the engine faces the other way.
thus the numbering is
-----1--- 2---3
Front----------Rear
-----4----5---6
Not sure if that is what you meant or not Loren.
Todd
Edited by tholyoak
Once you figure out which coil it is. I don't know how you test it. But.
Marvin who has worked at 2 local dealerships showed me a coil that looked new to me, but he said it was used. I asked him why he had a used coil and he said it was cracked. I have seen cracked coils before and the crack was very obvious.
I could not see the crack until he pointed it out to me. I would call it less than a hairline crack. I can see the crack in the picture only because he pointed it out to me.
well my guess was a good one. Bought the beru coilpack from worldpac for $49 and removed the coil over cylinder #4 then installed it in 15 minutes. Cleared the codes and fired it up, smooth idling & acceleration now. Thanks for all u help guys.
