Is there a way to make the horn Beep when the car (2001 996 C-2) is locked with the remote? I can't ever tell if the car is locked or not.
CGD
When I press the lock button on the remote the doors lock without the horn. When I press the lock button twice the horn beeps and the doors lock.
If you press twice the lock button, than you disable the interior sensors, that's way the horn beeps.
There is no way to do it correctly...Loren's approach is to have one of the sensors "open" so you get a warning beep indicating the car has an fault condition...the double press of the remote button disables the IR sensors so the beep essentially signals a fault condition as well.
