I'd like to have a performance alignment done to my Cayman S. Does anyone have recommended specs? I'll be using the car for AX, track, and street driving (but not daily driver).
The most camber you can get on the stock suspension w/o mods is about -1.0 on the front and -1.75 on the rear, which is not a bad compromise for street/track/AX. To get the max negative camber on the fronts, you have to push the strut mounting bolts all the way inboard in their slots.
Like you, I wanted a compromise for street and track, so I went for near zero toe on the fronts (0.04 toe-in) and slight toe-in on the rears (0.08) and as much caster as possible. If you are really competitive in AX, then you might want a touch of toe-out on the fronts, but it will make the car wander more on the highway.
