every since i bought the car 2nd gear has been "bumpy" when shifting from 1st to 2nd. down shifting from 3rd to 2nd is perfectly fine.
my first instinct is the syncro's however i have seen some post about the adjustments that are in the shifter and such
i will probably change the oil this weekend and see if that does anything, i didnt know if there was anything else i can do....
Does the car have short shift kit? I recall when I put mine in 2nd gear was "bumpy", so I ended up removing the kit
i don't believe so but i am the 3rd owner, how would i tell, i guess by removing the center console?
No, you just need to lift the shift boot. (4 snap clips)
yeah it just pulled right off, and it is the stock shifter
On my 1999 cab ---68000 miles -- when my car was cold sometimes it would pop out of 2nd if going slow. Sounded like a bad syncro in 2nd gear. I changed my trans fluid --- put in Royal Purple ( good reports on the net from race guys.) My old fluid looked fine
The new Royal Purple fluid fixed my problem. I would try that first.
Chuck 996 ----- Myrtle Beach, SC
well i put in the royal purple, and the tranny is acting better, took a couple of days for it to smooth out....
on a side note i went to porsche initially to but the fluid and they said they used mobile 1 syntetic 75-90, which is not on the "recomended" Mobil Mobilube PTX . they said they dont sell porsche manual transmission fluid which i thought was funny. no one carried the 2 recomended ones that are in the DIY list, however the royal purple seems to be working fine.....
You may want to buy a 90 weight gear oil that does not have the limited slip properties in it, LS friction modifiers act as a lubricant and can hamper synchro's to some extent. Currently Mobil 1 , Lucas, Ryal Purple and a like have LS friction modifiers already in it. The only one I have found is Redline 90 NS that does not. Of course if you have a LS differential then you have to use friction modifiers and have no choice.
Edited by KevinMac
the only oil the stores carried was the royal purple, and mobile 1 in terms of synthetic gear oil. i went to various places, i may look around for reline, maybe Dallas mustang carries it
You can buy it on the internet
