Will these Wheels fit my 986 boxster?
So far I've been able to get this much info on the wheels, They are Stockers from a 2001 996TT. I checked the 996tt parts cataloge and it looks like they have a variety of wheel sizes for the Turbo II's from
Fronts 8 - 8.5 x 18
Rears 10 - 11 x 18
8.5 x 18 were not stock on 996TT and only optional after MY03-- only on GT2.
The rears are likely ET 45 so I think that will be a real problem. I think you might get 10's under the rear fenders (if rolled) without rubbing (depending on tire size) but I don't think 11's will work.
Perhaps some Boxster owners can chime here...
CJ
Measuring from the outer edges of my Turbo twists, I have 18 x 8.5 in. front and 18 x10in. rear with no problem, in fact I have 7mm and 13mm spacers front and back respectively. Still plenty of room to spare. I put them on but don't recall what they came off of.
Regards, PK
Edited by pk2
