Im in the middle of buying some used Porsche Turbo 2's from a widebody 996 TwinTurbo... Will these wheels fit my boxster?
They are the wheels pictured in the image below.
So far I've been able to get this much info on the wheels, They are Stockers from a 2001 996TT. I checked the 996tt parts cataloge and it looks like they have a variety of wheel sizes for the Turbo II's from
Fronts 8 - 8.5 x 18
Rears 10 - 11 x 18
8.5 x 18 were not stock on 996TT and only optional after MY03-- only on GT2.
The rears are likely ET 45 so I think that will be a real problem. I think you might get 10's under the rear fenders (if rolled) without rubbing (depending on tire size) but I don't think 11's will work.
Perhaps some Boxster owners can chime here...
CJ
Measuring from the outer edges of my Turbo twists, I have 18 x 8.5 in. front and 18 x10in. rear with no problem, in fact I have 7mm and 13mm spacers front and back respectively. Still plenty of room to spare. I put them on but don't recall what they came off of.
Regards, PK
Edited by pk2
nice! thanks for the info PK2
Just to clarify, You have 7mm spacers in Front and 13mm Spacers in the Rear... Is that correct?
Edited by CJ_Boxster
