I saw the other thread which had the PDF file of the operation manual. While that's OK for just getting started there really isn't much good info in there. I am wondering if there is a mnaual or guids that shows what each menu item does. I am scared to go to half the menu items for fear of screwing things up and would like to know before I mess around anymore what each menu item does. Is there anything like that out there??
Too bad for you... the Porsche (NA) Tech training classes used to be in Las Vegas. I think they are only in Atlanta now - but then you would need to get hired by a dealership first. ;)
Ask your questions here and some folks that are more familiar with the tools will try to answer them.
Loren,
There are a ton of helpful people here and at the time I don't have any specific questions. More or less just want to know what all the menus do. Certainly I could follow the shop manuals which have the PST2 keystrokes in them but didn't really want to go through 2000+ pages :o
Loren,
You can try most of the options to change display or reset and see what does what. Its hard to mess things up with an actual PST2 or PST2 program that can't be quickly and easily fixed. The only time to be cautous would be if you are reprogaming. The rest makes for a very interesting adventure between you, your car and the PST2.
Example of what I'd like to know is what are the options for customizing the alarm, window operations, etc... Creature comfort things. Isn't there something like that which you can do with the PST2?
EDIT - It's the "coding" menus which really scare me :o
Side note - I did mess around with the "drive links" in a couple of the modules. It's pretty **** cool to turn fans on and off and the like :) (like a kid in a candy store)
Edited by slant911
If you start up the PST2 with the PC-card removed you can run the program in Simulation Mode. Then you can play to your heart's content without risk of messing anything up.
And you think the PST2 is complicated, just wait until you play with a PIWIS :o
Are the modules "active" in this mode? i.e. can you go to the modules and actually get things to happen?
I have not turned it on with the card removed but after turning it on and not hooked up to a car you really can't go anywhere as none of the modules are "active".
Thanks.
Tried it out and that was about what I was looking for. Some of the menus are not operational but most are.
Thanks.
  • 5 months later...
  slant911 said:
I saw the other thread which had the PDF file of the operation manual...
I searched high and low for the other thread and could not find it. Do you still have it bookmarked? Thanks.
  • 3 months later...
  Loren said:
http://www.renntech.org/forums/index.php?s...ost&p=44231
I've been using a Durametric and just today acquired a PC based PST-2. It looks familiar and I've been able to convert the units to US and have read everything in the help files. It took me a while to figure out what keys do what (the keyboard map in the help section is too small to read).
How do I save my configuration changes and properly shutoff the PC? The help file says to back it the whole way back to the startup page and then shut the unit off. Is this the proper procedure for a PC based unit?
Also what is the best way to backup the hard drive so that I can recreate it?
TIA
  Quote
If you set them in the PST2 config page at the startup screen then they are saved.
  Quote
According to Porsche and Bosch - yes.
  Quote
Just like you would any other hard drive - make an image of the drive. I use a product called Acronis True Image Home.
I take the drive out and put it in an external USB drive caddy and then use Acronis to back it up to (file) on another machine.
  Loren said:
  Quote
  Quote
  Quote
Great info, thanks!
My PST-2 works great but the Dell Laptop (C610) is really beat up and I am concerned it will not last long.
Any advice on moving the card and program to a new or newer laptop?
Where can I get a longer OBD-2 cable?
TIA
Make sure whatever laptop you move it to - that you can get video drivers for Windows 3.1.1 (yes, before Windows 95). Some of the old Toshiba's are good for this.
Chances are you will have to make a longer cable.
Last time I looked into this the IBM 600E is a good laptop because is color, faster, supports windows 3.11. Parts for and the laptop itself are very cheap right now on ebay.
I agree that will work too.
Thanks for the help guys, but has anyone found a way to run this on a new laptop?
Is there such a thing as an OBD-2 extension cord or are the pin outs on the car side unique to a Porsche?
  • 2 months later...
TIA
Hi, you can Diassemable your DELL to take out your HDD and purchase a DELL C600,C610,or C640 LAPTOP, The HDD are the same for all 3 of them, You can purchase one on EBAY in VERY GOOD condition with NO HDD so you dont have to Disassemble the one you buy on EBAY. If you need help Disassemabiling it EBAY also sells the MANNUELS., concerning the card, the PST2 will automatically pick it up. :thumbup:
:help: :help: This is my situation and hopefully you can help, i have V22 or PIWIS & PST2 on a IBM T30 HDD the only thing i need is a "card" as you mentioned, would you happen to have a spare PST2 card or know someone that could SELL me one. :thankyou: :help:
TIA
Check for the Bosch interface cards on European eBay - they show up there from time to time.
