help
posted a few weeks ago about my remote not working it started working when i pointed the 2 keys at each other and pressed voila the remote locking worked !!!
but its stopped working again tried most ideas but still no good DOH!!! new batteries everything else is fine led works c/l works when i use the key,
Are my keys shot ??? failing that is the fuse on my alarm odule playing up i tried last time to remove it from under the seat
but i did'nt want to break it anybody have any pic's of where the fuse is situated please and more importantly how it is removed
thanks
I found that my key remotes were tired and ineffective caused by the batteries not being held in properly by the battery retainer clip. I shimmed behind the battery with a few layers of tape until the clearance between the battery and the cover of the key was taken up. The best way to check this is to remove the remote from the key as if you were to change the battery. Press the lock/unlock button while supporting the battery. If it works then it confirms that this is the problem. Otherwise you need to remove the Antenna for the remote as it is in a foam sheath located in the A-pillarl It is a 10 minute job and is listed elsewhere in the forum. Search for 'remote antenna' I did both and my range is 65 feet.
  • 3 years later...
After 2 years of having a non functioning key less entry system,problem solved by a small furniture felt circle attached to the battery.works like a champ need to extend the range now.
