04 C4S - Black Plastic
I've had an aftermarket head unit conversion, now double DIN.
The climate/air con is now mounted in the bottom section and all I need is the fascia (curved at the bottom edges) to clip around it.
The OPC can't find the part number, ordered the part from PET as shown on a PCM fitted unit and got a rectangular fascia plate. :huh:
So if anyone has the part number then I'd be very grateful.
996.552.339.00.01C
It's tucked away on the PET under Body>Control Switch (aircon) - Illustration 813-45 - Item (4) for M573/M662
Richard,
I've checked PET and found it, I presume item (4) and opposed to 4 is the curved fascia, I think that's where we went wrong before.
Very much appreciated!
Iain
That's correct. The trim used at the top is more square cut. The one marked for M573/662 (aircon and PCM options) is the one with the curved sides used in the lower position.
