after an early morning b road blast about 2 hrs round trip, lots of bends, big hills and the odd mountain. noticed hydraulic fluid dripping from filler cap on resevoir, cap seems secure and o ring looks intact, the is a 06 c4s x51 with nearly 15k on the clock. anyone else seen this before? should i be worried
Was the reservoir over filled?
not as far as i know, the car came from an opc in the north of england, so i presume all the fluid levels to be correct,well hope
Seems pretty odd unless it was over filled, or the cap was overtightened, or the reservoir somehow took a blow that damaged it.
I would watch it daily for a week or two and see if you notice level change or other problems.
cheer's loren, appreciate the input. back to work tomorrow for a few weeks unfortunately, won't see the car for awhile but will take your advice next time i get home. all the best mate
