Guys,
My 2nd fob doesn’t seem to be working.
I bought my car used, 1st fob works fine. 2nd fob doesn’t work. The KEY does work in the ignition and starts the car.
Any ideas? Replace battery?
Is there a way to program or re-program the fob?
05 997 Carrera S
997 remotes are reprogrammable, you need E-pass, PIWIS and all the car keys you have. This is a dealer job.
Guys,
05 997 Carrera S
Sounds like you need to replace the battery! If you can start the car with the key, then it is already programmed!
