99 C2 coupe
I discovered today that:
1. Right HL low beam not working.
2. When engage high beam right head light high works.
3. Left high beam remains on low beam.
I don't have a clue why. Do you think that replacing the right unit will
solve the left sides problem (hopefully)?
Is changing head light major surgery?
bolobar
Keep it simple and switch the right low beam with the left high beam, if the result is inverse replace both bulbs.
Thanks, why didn't I think of that. :o :)
If you find it is not the bulb, then swap the left and right headlight relays in the fuse block. they are identical.
Good luck!! demosan
