ts my first manual car since 1988.
Everyng works fine.
One question when changing gears at high rpms 5k to 7k is it normal to feel the clutch pedal a bit tingly or a feeling of the rpms in the pedal when depressing the clutch? (kind of hard to explain) feels like the clutch is in sand
  • 4 months later...
Everyng works fine.
apparently it is normal because I noticed the same thing on my 2.7 cayman and was wondering whether to post about it :)
It is normal operation. The Dual Mass Flywheel(DMF) will cause the somewhat jiggly pedal and also a rattling noise when idling the car with the cluth pedal released. I wouldn't worry about it. Caymans are a blast to drive arent they? :D
