Some other abbreviations used in the PST2:
ABD - Automatic Brake Differential
ABS - Anti - lock Brake System
AHK - Anhängerkupplung (trailer coupling)
AHKS - Anhängerkupplung schwenkbar (pivoting trailer coupling)
CAN - Controller Area Network
CDR - Compact Disk Radio
CU - Control unit
CVN - Calibration Verification Number
DME - Digitale Motor Elektronik (engine control module)
DSN - Diagnosis Software Number
DSP - Digital Sound Processing
EU2/EU3/EU4 - European exhaust emissions standard
EOBD - European On Board Diagnosis
EZK - Elektronische Zundanlage mit Klopfregelung (electronic ignition system - with knock control)
GHV - Gurthhohenverstellung (seat belt height adjustment)
GW - Gateway
GPS - Global Positioning System
HFM - Heissfilmluftmassenmesser (mass air flow sensor) (MAF)
KESSY - Keyless Entry keyless go / control unit
LEV - Low Emission Vehicle (USA)
LH - Luftmassenmessung mit Hitzdraht (metering of the air quantity with hot-wire)
LWR - Automatic Headlight Beam Adjustment
ME - Motronic with E - gas
MMI - Man Machine Interface
MOST - Media Oriented Systems Transport
MY - Model Year (MY04 - >=as from MY04)
ORS - Off - Road Stabilizers (anti-roll bars)
PCM - Porsche Communication Management
PDAS - Porsche Dynamische Allrad Steuerung (Porsche dynamic four-wheel-drive control)
POSIP - Porsche Side Impact Protection System
PSD - Porsche Sperr Differential (Porsche limited–slip-differential)
PSM - Porsche Stability Management
PST 2 - Porsche System Tester 2
RDK - Reifen Druck Kontrolle (tyre pressure monitoring system)
RoW - Rest of the World
RF - Returnless Fuel
SBS - Sprach - Bedien - System (voice control system)
TC - Traction Control
