My 951 has a new timing belt, water pump and all that other 90k miles stuff. Yet, it idles at 2k rpm, at stop lights 9 times out of 10. sometimes, I can trick it by letting the clutch out a little and get it to "calm down" but not all the time. Also, the cooling fan runs (loud) almost all the time???
idle problem, make sure the throttle cable is not kinked or not sitting properly on the pulley. also check the idle micro switch and the throttle position switch
the fans sounds like it is direct wired
