Engine oil/tiptronic temps
What is the oil temp during extended drives at 4000RPM+ and high ambient temps?
Any idea what the tip-transmission fluid temp is under those same conditions?
No one drives these cars on the road at high-revs?
4000 RPM in 5th gear (Tiptronic) is over 110 MPH. Very few places you can do that sustained.
OK. Sustained 80MPH+ (3000RPM+) drives in the West (Nevada, Arizona, etc.) oil temps. No one?
Temperatures are 25 F higher at the track.
Normal Oil 200 F Water 175 F
At the track Oil 225 F Water 200 F
I average about 6 miles per gallon at the track. I reach a top speed
around 126 to 128MPH.
Paul
Edited by PAULSPEED
This will answer your question.
Two days ago I drove my C4S at speeds between 200 Km/h and 255 Km/h (+/-130 and 160 mph) for 160 KM (+/- 100 miles) at a toll highway somewhere in northeast Mexico, the exterior temperature was about 39°C (102°F), the oil temp reading was between 115°C and 125°C (240°F and 260°F) during the hi-speed driving. The coolant temperature stayed at dead center all the time (80°C, 175°F). The A/C was on all the time.
I was a little worried about the condition of the oil at such high temperatures but the oil temp. gauge doesn´t have a red line so I guess everything was OK. The normal operating temperature in city driving at high ambient temperatures (35°C-40°C) is between 95°C and 105°C (200°F and 220°F).
I should add that at that at almost 40°C and 1000' over sea level, the car seem capable of just a few more Km/h over the 255 km/h that I drove it, the acceleration at that point was pretty slow, maybe to 270 km/h tops (167 mph), well under the advertised 295 Km/h (183 mph).
I wonder if the top speed tests are done at ISA temps and at Sea Level, with the A/C turned off. Maybe under that conditions the car can reach the advertised top speed.
The drive was a pleasure anyway. I´m looking forward to the next one!!!
