In the next months I hope to buy a 996.
I am undecided whether to choose a carrera 4 tip (2002/2003) or a TT (2001/2002).
I have read a lot respect of RMS and I have understood that the TT is uninjured from this defect.
I concern to the breakups or porosity defects of the cylinder/block that can happens to the 996 carrera motor, is possible that does also happen on the TT,
or the cylinder/block is completely different ?
I hope to have been clear in my weak english.
Thanks in advance. :renntech:
the 996tt has a version of the earlier type bottom end. as per 993 and 964 so isnt effevted by the RMS or IMS failures that 996 carrera and boxsters suffer. i think i am right in saying that 2005 onwards carry a modified shaft so if you want to avoid these problems then i would go for the TT model on my02. just my opinion.
2005 unfortunately is not for my budget.
2005 onwards, you talk about the carrera or TT ?
