windscreen washer system problem
Hi guys long time to talk :) i
today i left my washer system be empty of water and when i try to cleen my glass water finished suddenly.
after an hour i put water in the water reservoir but when i try to clean glass water dont flow from the nozzles but come out of the drivers side wheel.
it come out of the inside thole plastic protector between body and wheel i think maybe a rubber come out from the pressure between the pump and the washing nozzle it is not inside the frond hood because i open the hood and remove the covers and unlucky i think it is in the left-side fender liner
can i fix it? please help
