Hi
My 97 c2s uses a quart to a quart and a half of oil every thousand miles. It has 107k miles with no leaks. I drive 60% in the city and the rest on open roads. I dont drive it very hard. Is this normal?
Any smoke?
Could be worn valve guides.
Only on start up from cold and not a lot. After a min or two there is no smoke. That oil use is not normal no?
Porsche says 1 quart every 600 miles is "acceptable".
I think it all comes down to what is acceptable to you. If it were my car and it used more than 1 quart every 1000 miles and there was exhaust smoke - I think I would look for causes and fix the problem.
Would getting the valve guides fixed be a big job?
