Clutch Accumulator Replacement
Common Symptoms - Hard pedal particularly with engine off, vibration and inexact point of engagement Tools 27mm open ended wrench (small head - I ground down an old wrench), 10mm socket Materials Accumulator 997-334-166-00, Hydraulic fluid Pentosin CHF 11S (or CHF 202) - Pump the clutch 25 times with the engine off to relieve any residual pressure in the system - all 4 wheels off the ground on jack stands or a lift. Easier to remove driver's side rear tire for better access if you're on stan
Edited by Danyol
