rstmartin, it is NOT just an oil & filter change. If you become a "Contributing Member" you can view the maintenance checklist. Well worth the small investment/donation.
The air filter is also replaced, and there are many checks that are performed. Including a fault code read out.
Sorry, but the air filter is a 30K event. Depending on the car, spark plugs may also be changed at 30K, but the 45K maintenance is the same as a 15K maintenance. Oil, oil filter, pollen filter.
sure there are other minor things are check, like to to see if there is air in the tires, that the CEL is not on, and there the fluids are at the proper level, i.e. stuff that should be checked regularly anyway, but the major tasks are oil, oil filter, and pollen filter.
here is a dealer maintenance sheet
oil change, oil filter is not required, pollen filter change, check/replace air filter if necessary,,,,,,,,
Edited by Loren
Removed Contributing Members only material
