What brand and where would i get stainless steel braided brake lines to replace the rubber hoses on a 01 996 C2.
J. Greer
someone told me stock breaklines are stainless steel with rubber overlayed on them for wear reasons....dont know if this is true or not
  • 8 months later...
Is this true? I'm thinking of upgrading my brake lines if this is not the case.
Edited by roastduck88
There is a steel material inside the stock rubber brake lines to prevent excessive expansion (one of the reasons why you must never compress the lines with a clip, vise grip or something similar), but have nothing to do with the real steel brake lines of a good brand (racing), which are a lot better in case of expansion and have a better result in pedal travel/pressure.
