OK… is anyone else having this problem?
In my town we do not have ANY gas stations that have Ethanol blends.
When I go on vacation in Orlando, I can only fill up with Ethanol blends (10%).
When I fill up in Orlando my Check Engine light comes on.
Is this just my Porsche being picky, or is this a sign of bigger problems?
Any help will be greatly appreciated,
(1999 Boxster. Mobil or BP/Amaco fuel, 93 Oct. only @ home)
FWIW, I generally fill up with 10% ethanol (it's what's at the shell stations, maybe everywhere here), and I haven't seen that at all. You could use an OBD II scanner, or get someone else to, to pull the fault codes; that's probably your best starting point in any case.
