I have an 01 Boxster and when I turn the ignition key on all the gauge lights come on except the check engine light. I removed the cluster and found that it was not as simple as a burnt out bulb, as there are tiny LEDs soldered onto the circiut board. Do these things burn out? Can they be replaced?
yes they can be replaced, check this site - porscheleds.com
