Hi there, new to the forum. I came across this site while searching the net for an answer to a problem I'm having, with no success. My friends '04 C4S Cabrio had an issue with the striker plate needing an adjustment, which I tried to some relief by using the wrong tools (torx isntead of the proper 8mm twelve point bit) it suficed at the time but I mentioned to him that he should have the screws properly tightened with the right tool. He procrastinated and the screwss worked themselves loose again to the point that the screws came completely out and the part that is in the door jamb slid down the jamb. I pulled the trim panels off to see if I could access that portion of the jamb, to no avail. Has anyone had this problem? and how was it resolved? I'm ready to take a torch to the chassis!!! eeeekk!!
Thanks.
