I have noticed a problem while opening the soft top.
The plastic window does not fold itself the right way.
I have to interrupt the opening, leave the car and use my hand to bring the window in the right position, because without doing so I have the fear that the window could break.
After bringing the window in position manually I can open the soft top without any problems.
Do you have any solutions for this problem?
When I always have to fix the window manually, and step out of the car, then why does my car have an automatic soft top.
Thank you for your help.
Turro, this is a very good question. The official Porsche answer is "Just let the plastic window fold the way it wants." When the weather is warm, >15C, I don't worry about how the window folds. When temperatures are lower, I make sure the window folds properly. This procedure is affecionately known as the "Boxster Chop". :)
Graeme
