I apologize I am new.  I just got my 00 C2 last week.  Is that an easy fix?  Can I just tighten them?
Yes, unless there is damage. Torque the 10 mm stabilizer mount to stabilizer to 34 ft-lbs. and the 10 mm stabilizer to side member to 48 ft-lbs. Also, check the stabilizer to shock mount should be a 12 mm bolt torque to 63 ft-lbs.
Chances are only one is loose but it's best to check them all.
